AIRBAGIT FBS-ACU-21-KIT3 KIT 1991-1995 ACURA LEGEND F STRUT CUSTOM SLEEVE R BAG AND BRAKE WITH 0.33 HP SMALL COMPRESSOR
Comes with dc380 vyclone 1/3 hp compressor. Check valve steel leader hose solenoid steel fittings 3/8 In. Airhose 70 on 120 off pressure switch. 3 gallon steel.
FeaturesAirbag &Bracket Install
Remove Spring and any Bumpstops that might interfere with the mounting or the bag travel.
Installing brackets require minor welding once you determine the exact placement of the brackets. Tack-Weld in place then install the bags and air them up with the supplied Schrader “Test Valve”
Make sure the upper and lower brackets are in relative alignment and make sure there is not body or metal contact when the bag travels up/down. Trim move or do whatever is necessary.
Price: 8726.59
